The Velocity Render Channel is a color or grayscale image that stores velocity information about objects that have moved between the current frame and the next frame.
Section | |||||
Section | ||||||||||||||||
Common Uses
The Velocity Render Element is useful for adding motion blur in post production at a composite level, without the need for rendering. See the render before and after compositing.
Before after | ||||||||||
Fancy Bullets | ||
