width55%
Uv Set Name – Specifies the UVW Channel to render by the name of the UV set.
Uv Index – Selects the UVW mapping channel of the connected Bitmap node
Refraction Ior – Sets the Index of Refraction.
Transform . P – Specifies how to position the map.
Transform . R – Specifies how to rotate the map.
Transform . S – Specifies the scale of the map.
Transform . Sh – Specifies a shear for the map.
Transform . Order – Specifies the order of the rotations.
width5%
width40%
Example: Creating 2D Transparency with the Sampler Info Node
You can effectively fade out objects in your scene using the V-Ray Sampler Info node. This method guarantees that the entire object is faded, including the internal structures, similar to how a 2D object would fade. Тo achieve this 2D transparency effect, follow the steps or copy the Node Editor Setup from the screenshot.
UI Text Box
width50%
  1. Create a V-Ray Material node.
  2. Create a V-Ray MultiSubTex node and attach it to the Opacity port of the V-Ray Material node.
  3. In the MultiSubTex General options, set the Mode to Use ID Generator Texture.
  4. Create a V-Ray Sampler Info node and attach its Transparency Level to the Switch ID Texture slot.
width50%
5. Go to the Texture List of the MultiSubTex and set the sub-texture's ID to 0.
6. Create a V-Ray User Color node and attach it to the sub-texture's Texture slot.
7. Set the MultiSubTexture's Default color to completely black (0, 0, 0).
8. Apply the V-Ray Material node to your geometry.
width50%
Node Editor Setup
Image Added
Click on the image to preview it in full size
width45%
Image slider
minLabel3D
startIndex1
maxLabel2D
Comparison between 2D and 3D transparency effect. Notice how the internal structures display in each case.
Panel
borderStylenone
Image Added
3D Transparency
Panel
borderStylenone
Image Added
Opaque
Panel
borderStylenone
Image Added
2D Transparency
