width45%
The default preview mode that displays the individual content of each cell. All enabled channels are drawn if their content is between the corresponding thresholds.
Only The Overlap Of
– When enabled, all channels in a cell must meet the selected threshold conditions to visualize the cell.
Temperature – Enables the representation of the temperature.
As fire – When enabled, the natural color of a hot black body is used for coloring the temperature. Otherwise, the color ramp is used.
Smoke – Enables the representation of the smoke.
Fuel – Enables the representation of the fuel.
Velocity – Enables the representation of the velocity.
Velocity Streamlines – Traces the velocity field of the cache files to generate a streamline preview.
Rainbow Color Curve Represents the Velocity Streamlines in rainbow colors, where red is the fastest, green is medium speed and blue is the slowest.
Streamlines Length Signifies the maximum length of each streamline in the preview. Adjusting the value will provide you with a guide/preview of the velocity field's motion. The Line's length is measured in voxels and at the lowest setting, the Streamlines will be no larger than a voxel.
Viscosity - Enables the representation of the viscosity channel.
RGB – Enables the representation of the RGB channel.
Auto Range – When enabled, automatically adjusts the preview ranges of visible channels for the current frame so that important data is always visible and the preview is always quick.
width55%
