Chaos Scans is a scanning technology which converts real-world materials such as textiles, plastic, paint, and metal into digital materials. These can be used in 3D software tools to create photorealistic computer-generated images and animationanimations.
Why should I use Chaos Scans?
Since Scans is aimed at accurately reproducing reality, the Scans materials do not allow the same level of control as a custom-built materialmaterials. The .vrscans file contains a complete data set, so there are no separate texture maps.
Do Scans materials support render elements?
Since Starting with V-Ray Next, there is support for some Render Elements.
The Chaos Scans plugin is the part of V-Ray (versions 3.5 6 and above) and Corona (versions 9 and above) which provides the UI for importing, modifying, and using the Scans materials in:
Fancy Bullets | ||
