Saves the render element currently displayed in the VFB using a specified file format.
Press and hold the Save button:
Save all – Saves each render element as a separate file using a specified file format.
Save CXR – Stores all the information from the VFB (all render elements, including the LightMix, tone mapping, denoising data, etc.) inside a single CXR file.
Copies the content of the Corona VFB to the native C4D Picture Viewer.
Copies the multi-pass currently displayed in the VFB to the clipboard.
UI Text Box
type
tip
Useful for pasting the content of the VFB into other apps without saving the file.
Forces a VFB refresh. Useful mostly when using very high VFB update intervalvalues.
Clears the VFB.
Toggles visibility of the side panel.
Toggles render region drawing mode.
Left-click and holdto draw a region. Drag a region border with holding the Control key to enable "fuzzy regions".
Holding the mouse over the Region button toggles all regions on and off (Disable All) , and remove removes all (Remove All) existing regions.
Allows to pick object objects directly from the VFB.
Left-click to select an object. Right-click to select an object or set the camera focus to the selected point in the scene. Works also in interactive rendering.
Selects the render element multi-pass to be displayed in the VFB.
Zooms in.
Zooms out.
Resets zoom.
The Stop button stops
Stops the rendering process without discarding any additional data or post-rendering actions.
This is the same as the "Stop rendering..." button in the Cinema 4D Picture Viewer window
UI Text Box
type
note
When denoising is enabled, pressing the Stopbutton stops the rendering process and proceeds to denoising post-rendering actions.
The Cancelbutton stops rendering the
render
rendering process and discards denoising or post-rendering actions
as well as skips saving output files (if were set up).
