width60%
The Outlines render element stores a mask for both the global and individual material outlines. The outline color and exposure compensation are ignored.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelOutlines
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Outlines
||V-Ray Asset Editor|| > Create Asset (left-click) > Render ElementsOutlines
width60%
Denoise – Specifies whether to denoise this render element.
Invert Color – When enabled, inverts the resulting render element colors.
width5%
width35%
Compositing
width10%
width80%
Outlines is often used for creating cartoon-like renders. This can be achieved in addition with the Diffuse Render Element in a compositing or editing software.
Image Modified
width10%
