width60%
Stores only direct lighting information with no diffuse component.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelRaw Light
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Raw Light
||V-Ray Asset Editor|| > Create Asset (left-click) > Render ElementsRaw Light
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Raw Lighting Render Element is useful for changing the appearance of direct lighting in a compositing or image editing software. In this example, you can see how the image looks before and after post-production.
width5%
width35%
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
Raw Light x Diffuse = Lighting
Image Added
width10%
