width60%
Shows the sum of raw lighting (both direct and indirect) in the scene, without any diffuse details.
width5%
width35%
Before after
afterLabelBeauty
darktrue
beforeLabelRaw Total Light
Panel
Image Added
Panel
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Raw Total Light
||V-Ray Asset Editor|| > Create Asset (left-click) > Render ElementsRaw Total Light
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Raw Total Light Render Element is useful for changing the appearance of the entire lighting of the scene, after rendering, using a compositing or image editing application. A Cryptomatte Render Element  is used to isolate the floor, the windows along with the curtains and the stone fence, and the ceiling. Then the Raw Total Light Render Element is brightened and tinted differently for each element to show the range of editing possibilities. See the render before and after compositing.
width5%
width35%
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
Raw Total Light Diffuse = Total Light
Image Added
Raw Light + Raw GI = Raw Total Light
Image Added
width10%
