width60%
 Stores Stores direct lighting information. The indirect illumination in the scene does not affect this element.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelLighting
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Lighting
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Lighting
width60%
 Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Lighting Render Element is useful for changing the appearance of direct illumination after rendering in a compositing or image editing application. In the example, a warm tone is applied to the lights in compositing.
width5%
width35%
Before after
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
Raw Light Diffuse = Lighting
Image Added
width10%
