width60%
Stores light scattered by Subsurface Scattering materials.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelSubsurface Scattering
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Subsurface Scattering
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Subsurface Scattering
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Subsurface Scattering Render Element is useful for changing the appearance of SSS elements, after rendering, in a compositing or image editing software. In the example, the scattering color is changed to red using the SSS RE. See the render before and after compositing.
width5%
width35%
Before after
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
The Subsurface Scattering Render Element is added to the Beauty composite to form the final image.
Image Added
width10%
