width60%
This element works as a reverse mask for shadows. It is a color image that can be used to lighten, darken or tint shadows. Shadows can be lightened in the composite by adding this render element, or darkened by subtracting this render pass from the final composite.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelShadows
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Shadows
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements Shadows
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Shadows Render Element is useful for changing the appearance of shadowed areas in a compositing or image editing application. In the example the Shadows RE is subtracted from the Beauty element, resulting in a darker render.
width5%
width35%
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
Raw Shadows x Diffuse = Shadows
Image Added
width10%
