width60%
Shows areas where light doesn't reach. Compare with the Raw Shadow Render Element, which gives areas of cast shadows.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelMatte Shadows
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Matte Shadows
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Matte Shadows
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Matte Shadows Render Element is useful for changing the appearance of shadowed areas in compositing or image editing software. In the example, the shadows are brightened and tinted with a warmer tone using the Matte Shadows RE. See the render before and after compositing.
width5%
width35%
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
Matte Shadows + Raw Light
Image Added
width10%
