width60%
Stores indirect lighting information with no diffuse component.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelRaw GI
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Raw GI
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Raw GI
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
Once the scene is rendered, the Raw Global Illumination Render Element is useful for changing the appearance of indirect lighting in a compositing or image editing application. See the Raw Global Illumination before and after editing and the resulting images.
width5%
width35%
Image slider
Panel
borderStylenone
Image Added
V-Ray Raw Global Illumination
Panel
borderStylenone
Image Added
Original Beauty composite
Panel
borderStylenone
Image Added
V-Ray Raw Global Illumination edited
Panel
borderStylenone
Image Added
Beauty composite edited
Compositing
width10%
width80%
Raw GI x Diffuse Global Illumination
Image Added
width10%
