width60%
Add Light (Generic Data) – This Light output should be connected to the V-Ray Renderer's Light input slot.
Environment (Generic Data) – V-Ray Environment to be connected to the V-Ray Renderer's Environment input slot.
width5%
width35%
Right-click on the component to see more options.
Footnotes
Fancy Bullets
typecircle
  • Starting with V-Ray6.10.10, the migration of Loading Rig components , from projects created with   V-Ray 6.10.00 into newer versions, requires parameter rewiring.
