Add Light (Generic Data) – Light output that can be connected to a Renderer.
Example
Light Omni component connection. Note that an Environment component with a black color plugged in the GI input parameter is used as an override to turn off the default Environment lighting. If there is no Environment input in the Render component V-Ray always creates one internally.
Section | ||||||||||
