width50%
The Plain Force pushes a fluid according to the helper's orientation. It is used to produce a gravity or wind effect.
The dynamics are controlled by two parameters, that balance between predictability and natural behavior: the Strength of the force (magnitude), and Drag.
UI Text Box
typenote
Note that the Drag determines how much the fluid’s behavior is suppressed, or how closely it follows just the Plain Force, while also preventing the fluid from continuously accelerating forever.
UI Expand
titleUI Path: ||Phoenix FDl|| > Create > Plain Force
Image Removed
Image Added
width50%
Strength | strengthunits – Specifies the acceleration force measured in scene units/sec^2.
