This section contains information about the lighting components in V-Ray for Grasshopper.
width50%
The Lighting tab displays all the V-Ray lights components. They are the following: V-Ray Light Rig Dome, V-Ray Light Rig Simple, V-Ray Light Rig Sun System, V-Ray Dome Light, V-Ray Light Directional, V-Ray Light IES, V-Ray Light Mesh, V-Ray Light Omni, V-Ray Light Rectangle, V-Ray Light Sphere, V-Ray Light Spot and V-Ray Light Sun.
UI Text Box
typeinfo
Note that all lights attached to the V-Ray Render component are exported through the Render in Project component if connected.
width5%
width45%
Align
aligncenter
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/2lkoLdoHPzU?list=PLm2Irfq-UvZ3D79zJ1kQuugYllXluT4yP" title="V-Ray for Grasshopper - Lighting your definition" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Example: Default Light
To disable the environment, connect an Environment component with black GI to the V-Ray Render component.
To disable the light, connect a new lighting component or a Rig Dome component with disabled “Light On” parameter to the V-Ray Render component.
width10%
width80%
Image slider
Panel
borderStylenone
Image Added
Default Light and Environment
Panel
borderStylenone
Image Added
Environment with GI that is overridden with black color
Panel
borderStylenone
Image Added
Rig Dome light with disabled Light On
width10%
Fancy Bullets
typecircle
  • Grasshopper creates default lighting and environment in every scene if no inputs specified in the V-Ray Render component.
