width60%
This rig consists of a Directional light, Reflection environment and a background texture. Global Illumination is enabled and the color of the GI environment can be controlled.
width5%10%
width35%25%
Input Parameters
Gradient On (Boolean) – Enables the use of a screen-mapped gradient texture for background. When disabled a black background color is used.
Reflection Environment On Reflect Env. On (Boolean) – Enables a default reflection environment texture. When disabled a black environment color is used.
GI Environment Env. Color (Color) – This slot provides connection to the GI Environment Color.
Light Intensity (Number) – Provides a slot to control the Intensity of the Directional light.
Output Parameters
Add Light (Generic Data) – This Light output should be connected to the V-Ray Renderer's Light input slot.
Environment Env (Generic Data) – V-Ray Environment to be connected to the V-Ray Renderer's Environment input slot.
Example
width5%
width50%58%
Image Modified
Component Connection with Light Rig Simple. Click on the image to enlarge it.
width42%40%
width5%
Footnotes
Fancy Bullets
typecircle
  • Loading Rig components from projects created with V-Ray 6.10.00 into newer versions, requires parameter rewiring.
