This page provides information about the Light Directional in V-Ray for Grasshopper.
width60%
The V-Ray Directional Light is a V-Ray specific light source plugin that can be used to create physically accurate area lights. It can be connected to the V-Ray Render component or any V-Ray Light Rig which automatically adds it to the rendered scene.
width5%
10%
width35%25%
Image Removed
Image Added
Input Parameters
On (Boolean) – Enables or disables the light source.
Shadow Softness (Number) – Sets the shadow softness. Zero (0.0) makes the shadows perfectly sharp, larger values produce blurrier shadows.
Output Parameters
Add Light (Generic Data) – Light output that can be connected to a V-Ray Render component.
Example
Light Directional component connection.
width52%47%
Image RemovedImage Added
width48%53%
