Section | |||||||||||||||||||||||||
UI Text Box | ||
Import is available only after a .vrscene file is specified in the File field and an extract assets folder is specified in the Path field. If the content of any of these 2 fields is not properly set, then the OK button is grayed out. |
UI Text Box | ||
The Enscape .vrscene files keep relative paths to their external assets (.ies and .dds files). Make sure that your .vrscene file and its respective .data folder where the external assets reside (if available) are placed together before proceeding with Enscape .vrscene import. Otherwise, external assets may not be found on import. |
UI Text Box | ||
The Cancel button interrupts the import progress of the .vrscene file to its current state. Clicking the button early in the process may result in only parts of the geometry being imported into 3ds Max; while using it towards the end can lead to incomplete shading import. As of now, there is no way to resume the same import once it's been canceled. |
UI Text Box | ||
Note that it may take several seconds after the import progress bar has finished filling up before the imported content is available for use in 3ds Max viewports. This delay is expected with heavy scenes and corresponds to the loading processes in 3ds Max, akin to those used when opening a saved heavy .max scene. |
Supported features
Here is what to expect when importing Enscape exported .vrscene files:
Enscape features in .vrscene | Enscape .vrscene import support |
Camera | YES |
Geometry | YES |
Materials | YES |
Maps | YES |
Artificial lights | Partial6 |
Sun light | Yes |
Clouds | Yes |
Environment map |
Unsupported features by design
7 – Contrails are not available in the .vrscene exported by Enscape so they do not appear in the render. You can manually enable them in the VRaySun parameters and adjust their values according to your preferences.
8 – Enscape sky presets are imported as VRaySky without any additional preset-specific customization.
