Corona for Cinema 4D
tachments (44)
Corona for Cinema 4D Home
Shaders
Corona Tile Shader
Old Version
4
changes.mady.by.user
Benjamin Rosas
Saved on
Feb 01, 2024
compared with
New Version
5
Benjamin Rosas
Saved on
Feb 01, 2024
Previous Change: Difference between versions 3 and 4
Next Change: Difference between versions 5 and 6
View Page History
This line was added.
This line was removed.
Formatting was changed.
width
50%
Image slider
Panel
title
Global scale - 25%
Panel
title
Global scale - 50%
Panel
title
Global scale - 100%
Panel
title
Global scale - 200%
width
50%
Image slider
Panel
title
Tile Pattern - Common Bond
Panel
title
Tile Pattern - Double English Cross
Panel
title
Tile Pattern - Monk Bond
Panel
title
Tile Pattern - Stretcher Bond
width
50%
Image slider
Panel
title
Corner radius - 0.1
Image Added
Panel
title
Corner radius - 0.25
Image Added
Panel
title
Corner radius - 0.5
Image Added
width
50%
Image slider
Panel
title
Gap thickness - 0
Image Added
Panel
title
Gap thickness - 0.1
Image Added
Panel
title
Gap thickness - 0.25
Image Added
Panel
title
Gap thickness - 0.5
Image Added
Panel
title
Gap thickness - 0.75
Image Added
