Round Edges Enabled– Enables the round edges effect, which uses bump mapping to smooth out the edges of the geometry during render time.
Radius– Specify a radius (in world units) for the Round Edges effect. Since the actual geometry is not being changed and only the normals of the faces are affected, large values may produce undesirable effects.
Consider Same Object Only– When enabled, the rounded corners are produced only along edges that belong to the object, which has the attribute applied. When disabled, rounded corners are also produced along edges formed when the object with the attribute intersects other objects in the scene.
Corners– Choose which edges are considered in the calculation. Possible options are:
Covex and Concave– Considers all edges. Convex Only– Only applies Round Edges effect to edges with convex angles. Concave Only– Only applies Round Edges effect to edges with concave angles.
width
5%
width
38%
width
57%
Context– Allows the attachment of a Context node (UVW generator) to adjust the UVWs of the texture.For more information, visit theContext Nodes page.
