width57%
The V-Ray MtlOSL node can be used to load OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray.
The V-Ray MtlOSL node plug-in can be used with shaders that use closure color output parameters.
If you wish to disable the material preview or adjust its quality to save processing power, you can do so from the Material Node.
width5%
width38%
