The Scene Converter is a tool you can use to convert scenes made with other renderers to Corona. It automatically converts materials, shaders, lights, and more. It is installed with Corona by default and can be launched from the Corona menu.
UI Text Box
type
note
The Scene Converter tool works only if you have both Corona and the other renderer installed on the machine where you are using it. It is fine to use the trial or even an expired trial license of the other renderer. For example, if you are converting V-Ray materials to Corona, you need to have both Corona and V-Ray installed on your computer.
UI Text Box
type
warning
The Scene Converter tool from Corona 11 supports converting elements from V-Ray and the native Standard Cinema 4D render engine.
Instructions on how to convert a scene are as follows:
Open a previously created scene or import a model
Open the Corona menu and click on the Convert Scene tool
Decide if all available and supported elements are going to be converted or only part of them.
Start the conversion process and wait for the result.
The Scene Converter tool is located in the Corona menu.
UI Path: ||Corona menu|| > Convert scene...
width
5%
width
45%
Image RemovedImage Added
Options
width
50%
List – All available and supported elements are listed here when automatically detected in the scene project.
UI Text Box
type
tip
Elements to be converted can be manually selected by enabling/disabling the corresponding checkboxes.
Select active materials – Using this button enables the checkboxes only for the listed materials available for conversion. The remaining elements available for conversion are disabled.
Select active objects – Using this button enables the checkboxes only for the listed objects available for conversion. The remaining elements available for conversion are disabled.
Metalness – This allows for choosing whether all the converted materials should be metals or non-metals or if the converter should decide automatically based on the material's reflectance parameters before conversion. Available modes are:
Fancy Bullets
Autodetect – Corona attempts to automatically detect whether a material should be converted to a metal or non-metal. This may not always be accurate, so some manual adjustments may be needed after the conversion.
No metal – This mode sets the Metalness mode to Non-metal for all the converted materials.
All metal – This conversion mode sets the Metalness mode to Metal for all the converted materials.
Convert shaders – This allows for selecting between different conversion methods to use for the shaders.
Cancel – Cancels the elements conversion.
Convert – Starts the conversion of the selected available supported elements.
UI Text Box
type
note
The Scene Converter tool tries to keep as many of the original settings as possible in newly created materials. For Refractive, Translucent, and Volumetric materials, sometimes there will be more shaders/nodes than in the original material. Nevertheless, the converted materials will look and render just fine.
