Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Div
classRespColumnsHeader
Official Release
Date - March 27, 2024
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage, 2.3.0 Build
urlhttps://download.chaosgroup.com/?platform=47&product=63
HTML
<iframe width="100%" height="350" src="https://www.youtube.com/embed/-iZz19TEIfI?si=Bc2p_qwpjWyn71zZ" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap20px
ClassRespColumns3
Div
classRespColumns3
New Features
Materials
Fancy Bullets
  • Support for rendering V-Ray Blend Material (BRDFLayered).
Render element
Fancy Bullets
  • Support for the Multi Matte render element.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Multi+Matte+Details
UI/UX
Fancy Bullets
  • Added viewport toggle filter for the light gizmos.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Toolbars#Toolbars-Toptoolbar
  • Added option to improve desktop responsiveness while rendering.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Edit+Menu
  • Added information, in the status bar, for the host application used for Live Link.
  • Added ability to rename of objects created inside Vantage (Fur, Scatter, Lights, Multi Matte) with a context menu or double-click on object name.
Output
Fancy Bullets
  • Added AV1 codec for video encoding, enabled by default (if supported by GPU).
    UI Button
    colorblue
    iconinfo
    titleDetails
Modified
Displacement
Fancy Bullets
  • Improved memory used for displacement by varying tessellation level within a mesh.
Denoiser
Fancy Bullets
  • Updated Intel Open Image Denoise to version 2.2.
Light Cache
Fancy Bullets
  • Improved Light Cache to slightly better preserve low intensity samples.
UI/UX
Fancy Bullets
  • Chaos Cosmos Browser UI responsiveness.
Fixes
Displacement
Fancy Bullets
  • Random displacement when using unsupported secondary UV channel of the geometry object.
Scene states
Fancy Bullets
  • Broken sub-states after dropping Environment texture.
Fancy Bullets
  • Wrong Live Link update for Nodes with unsupported materials.
  • Wrong rendering of Glossy Refraction with rotated texture during Live Link with Rhinoл
Lights
Fancy Bullets
  • Sun azimuth rotation values to match geographical azimuth. Old saved .vantage files will be automatically updated to use new values on Save.
Collision
Fancy Bullets
  • Missing "Height ratio" update when collision "Height tolerance" is changed.
Clouds
Fancy Bullets
  • Wrong cloud shading with sun slightly under the horizon.
Lighting
Fancy Bullets
  • Wrong lighting when rendering using direct light reservoir resampling and the scene contains a normal map.
  • Refraction artifacts when rendering with direct light reservoir resampling.
UI/UX
Fancy Bullets
  • Disappearing toolbar in the Debug Log window after second opening.
  • Hiding of the HQ rendering dialog while "Always on top" is enabled.
Denoiser
Fancy Bullets
  • Streak artifacts with Optix denoiser and multi GPU setup.
  • Broken temporal (“reduce flickering”) denoising in multi GPU mode.
