Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Div
classRespColumnsHeader
Official Release
Date - June 2, 2024
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage, 2.5.0 Build
urlhttps://download.chaosgroup.com/?platform=47&product=63
HTML
<iframe width="100%" height="350" src="https://www.youtube.com/embed/cC8SC3uj9yE?si=f4q8UIiO8wVMGtSp" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap20px
ClassRespColumns3
Div
classRespColumns3
New Features
Virtual Reality
Fancy Bullets
  • Initial(WIP) support for interactive rendering in VR headsets.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Toolbars#Toolbars-Toptoolbar
UI Text Box
typenote
Chaos Vantage is compatible with all VR headsets (tested with Meta Quest 2, Meta Quest Pro, Meta Quest 3, HTC Vive, and Varjo Aero). Wireless connection is supported, but for smooth performance a tethered connection is recommended. Ensure an appropriate OpenXR runtime is set in the VR's respective app:
  • Windows Mixed Reality: "Mixed Reality Portal" > "Settings" > "Set up OpenXR".
  • Oculus: "Oculus" app > "Settings" > "General" > "Set Oculus as Active".
  • SteamVR: "SteamVR" app > "Settings" > "Developer" > "Set SteamVR as OpenXR Runtime
Animation
Fancy Bullets
  • Support for Chaos Cosmos animated vegetation assets.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Chaos+Cosmos+Browser#ChaosCosmosBrowser-AnimatedAssets
Materials
Fancy Bullets
  • Support for VRayEdgesTex in bump and rounded corners.
Geometry
Fancy Bullets
  • Support for animated partial object visibility.
Rendering
Fancy Bullets
  • Support for ACEScg rendering color space.
  • Tool for quickly saving a previz video with DLSS.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Tools+Menu
UI/UX
Fancy Bullets
  • Search filtering and sorting for scene objects, lights, and cameras.
  • Progress bar for importing assets.
  • Added meter scale information in the log and Scene stats.
  • Added "Flip horizontally" option to the Background image.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Environment+Tab#EnvironmentTab-Background
  • Added ability to drag and drop files onto FilePath property labels(LUTs, Environment texture, Background texture, Point, Spot, Directional Projection textures).
Color Corrections
Fancy Bullets
  • Loading chromatic aberration from VFB settings in .vrscene.
Modified
Decals
Fancy Bullets
  • Added decal option to lock the width/length ratio.
  • Improved the "place decals" tool to be activated when importing or dragging decals from the Chaos Cosmos browser and to load the decal properties.
UI/UX
Fancy Bullets
  • Improved the "Always on top" behavior, now it is disabled while HQ rendering.
  • Improved UI - now distance parameters display with scene units.
  • Improved the camera settings layout.
  • Improved the highlighting and selection in scenes with millions of instances.
Environment
Fancy Bullets
  • The default sun is now auto-enabled when it is the only light in the scene.
  • Added Improved shading option to the clouds that improves self-shadowing.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Environment+Tab#EnvironmentTab-Clouds
Performance
Fancy Bullets
  • Texture loading speed is now 5-10% faster.
  • Improved acceleration structure rebuilds and instance updates for better performance.
Vantage file
Fancy Bullets
  • Merged assets as a result of "Open file as config only" now are properly saved in the .vantage file.
Installer
Fancy Bullets
  • New default install directory is C:\Program Files\Chaos\Vantage\. For versions prior to Chaos Vantage 2.5, the default location is - C:\Program Files\Chaos Group\Vantage\
Fixes
Environment
Fancy Bullets
  • Visible strip artifacts on clouds.
  • Incorrect environment rotation when using the "Flipped" option in Maya
Decals
Fancy Bullets
  • Decals not rendering from Live Link from Revit or other V-Ray 6.1 builds.
  • Decals not updating on animated objects under specific circumstances.
  • Transform animation from .vrscene being ignored for decals.
Textures
Fancy Bullets
  • Incorrect saturation of textures when dynamic textures are enabled.
  • Reduced checker artifacts with UVWRandomizer random rotation and certain normal maps when dynamic textures are enabled.
UI/UX
Fancy Bullets
  • Overlay issue when using multiple GPUs with OptiX or DLSS upscaling.
  • Incorrect change of the "View mode" after "Frame Selected/Scene" action.
  • Hiding of the "Create scene state" dialog when "Always on top" option is enabled.
  • Undo transformation for objects in very large scenes.
  • Non-functioning undo shortcut while the Transform Dialog is open.
Vantage file
Fancy Bullets
  • Generation of additional clone objects when opening the scene as config only.0
