changes.mady.by.user Unknown User (ivan.mavrov)
Saved on Sep 01, 2016
Here is the shader code:
/// Oiginal notice: /* * srdnoise23, Simplex noise with rotating gradients * and a true analytic derivative in 2D and 3D. * * This is version 2 of srdnoise23 written in early 2008. * A stupid bug was corrected. Do not use earlier versions. * * Author: Stefan Gustavson, 2003-2008 * * Contact: stefan.gustavson@gmail.com * * This code was GPL licensed until February 2011. * As the original author of this code, I hereby * release it into the public domain. * Please feel free to use it for whatever you want. * Credit is appreciated where appropriate, and I also * appreciate being told where this code finds any use, * but you may do as you like. */ /// Translated and modified by Ivan Mavrov, Chaos Group Ltd. 2016 /// Contact: ivan.mavrov@chaosgroup.com /// 3D Simplex flow noise implementation. /// Returned values are in the [0, 1] range. float simplexFlowNoise3D(point position, float flow, output vector dNoise) { int perm[512] = { 151,160,137,91,90,15, 131,13,201,95,96,53,194,233,7,225,140,36,103,30,69,142,8,99,37,240,21,10,23, 190, 6,148,247,120,234,75,0,26,197,62,94,252,219,203,117,35,11,32,57,177,33, 88,237,149,56,87,174,20,125,136,171,168, 68,175,74,165,71,134,139,48,27,166, 77,146,158,231,83,111,229,122,60,211,133,230,220,105,92,41,55,46,245,40,244, 102,143,54, 65,25,63,161, 1,216,80,73,209,76,132,187,208, 89,18,169,200,196, 135,130,116,188,159,86,164,100,109,198,173,186, 3,64,52,217,226,250,124,123, 5,202,38,147,118,126,255,82,85,212,207,206,59,227,47,16,58,17,182,189,28,42, 223,183,170,213,119,248,152, 2,44,154,163, 70,221,153,101,155,167, 43,172,9, 129,22,39,253, 19,98,108,110,79,113,224,232,178,185, 112,104,218,246,97,228, 251,34,242,193,238,210,144,12,191,179,162,241, 81,51,145,235,249,14,239,107, 49,192,214, 31,181,199,106,157,184, 84,204,176,115,121,50,45,127, 4,150,254, 138,236,205,93,222,114,67,29,24,72,243,141,128,195,78,66,215,61,156,180, 151,160,137,91,90,15, 131,13,201,95,96,53,194,233,7,225,140,36,103,30,69,142,8,99,37,240,21,10,23, 190, 6,148,247,120,234,75,0,26,197,62,94,252,219,203,117,35,11,32,57,177,33, 88,237,149,56,87,174,20,125,136,171,168, 68,175,74,165,71,134,139,48,27,166, 77,146,158,231,83,111,229,122,60,211,133,230,220,105,92,41,55,46,245,40,244, 102,143,54, 65,25,63,161, 1,216,80,73,209,76,132,187,208, 89,18,169,200,196, 135,130,116,188,159,86,164,100,109,198,173,186, 3,64,52,217,226,250,124,123, 5,202,38,147,118,126,255,82,85,212,207,206,59,227,47,16,58,17,182,189,28,42, 223,183,170,213,119,248,152, 2,44,154,163, 70,221,153,101,155,167, 43,172,9, 129,22,39,253, 19,98,108,110,79,113,224,232,178,185, 112,104,218,246,97,228, 251,34,242,193,238,210,144,12,191,179,162,241, 81,51,145,235,249,14,239,107, 49,192,214, 31,181,199,106,157,184, 84,204,176,115,121,50,45,127, 4,150,254, 138,236,205,93,222,114,67,29,24,72,243,141,128,195,78,66,215,61,156,180 }; // Gradient component that leads to a vector of length sqrt(2). // float a = sqrt(2)/sqrt(3); float a = 0.81649658; vector gradientUBase[16] = { vector( 1.0, 0.0, 1.0), vector( 0.0, 1.0, 1.0), vector(-1.0, 0.0, 1.0), vector( 0.0, -1.0, 1.0), vector( 1.0, 0.0, -1.0), vector( 0.0, 1.0, -1.0), vector(-1.0, 0.0, -1.0), vector( 0.0, -1.0, -1.0), vector( a, a, a), vector(-a, a, -a), vector(-a, -a, a), vector( a, -a, -a), vector(-a, a, a), vector( a, -a, a), vector( a, -a, -a), vector(-a, a, -a) }; vector gradientVBase[16] = { vector(-a, a, a), vector(-a, -a, a), vector( a, -a, a), vector( a, a, a), vector(-a, -a, -a), vector( a, -a, -a), vector( a, a, -a), vector(-a, a, -a), vector( 1.0, -1.0, 0.0), vector( 1.0, 1.0, 0.0), vector(-1.0, 1.0, 0.0), vector(-1.0, -1.0, 0.0), vector( 1.0, 0.0, 1.0), vector(-1.0, 0.0, 1.0), vector( 0.0, 1.0, -1.0), vector( 0.0, -1.0, -1.0) }; // Helper function to compute the rotated gradient. vector getGradient(int index, float sinTheta, float cosTheta) { int safeIndex = index % 16; vector gradientU = gradientUBase[safeIndex]; vector gradientV = gradientVBase[safeIndex]; return cosTheta * gradientU + sinTheta * gradientV; } // Skewing factors for the 3D simplex grid. // float F3 = 1.0 / 3.0; // float G3 = 1.0 / 6.0; float F3 = 0.333333333; float G3 = 0.166666667; float G3a = 2.0 * G3; float G3b = 3.0 * G3 - 1.0; // Skew the input space to determine the simplex cell we are in. float skew = (position[0] + position[1] + position[2]) * F3; point skewedPosition = position + skew; point skewedCellOrigin = floor(skewedPosition); // Unskew the cell origin float unskew = (skewedCellOrigin[0] + skewedCellOrigin[1] + skewedCellOrigin[2]) * G3; point cellOrigin = skewedCellOrigin - unskew; // The offset from the cell's origin a.k.a point 0 vector offset0 = position - cellOrigin; // The second point offset from the cell origin in skewed space. vector skewedOffset1; // The third point offset from the cell origin in skewed space. vector skewedOffset2; if (offset0[0] >= offset0[1]) { if (offset0[1] >= offset0[2]) { // X Y Z order skewedOffset1 = vector(1, 0, 0); skewedOffset2 = vector(1, 1, 0); } else if (offset0[0] >= offset0[2]) { // X Z Y order skewedOffset1 = vector(1, 0, 0); skewedOffset2 = vector(1, 0, 1); } else { // Z X Y order skewedOffset1 = vector(0, 0, 1); skewedOffset2 = vector(1, 0, 1); } } else { if (offset0[1] < offset0[2]) { // Z Y X order skewedOffset1 = vector(0, 0, 1); skewedOffset2 = vector(0, 1, 1); } else if (offset0[0] < offset0[2]) { // Y Z X order skewedOffset1 = vector(0, 1, 0); skewedOffset2 = vector(0, 1, 1); } else { // Y X Z order skewedOffset1 = vector(0, 1, 0); skewedOffset2 = vector(1, 1, 0); } } // A step of (1, 0, 0) in skewed space means a step of (1 - G3, -G3, -G3) in regular space. // A step of (0, 1, 0) in skewed space means a step of (-G3, 1 - G3, -G3) in regular space. // A step of (0, 0, 1) in skewed space means a step of (-G3, -G3, 1 - G3) in regular space. // The offset from point 1 in regular space. vector offset1 = offset0 - skewedOffset1 + G3; // The offset from point 2 in regular space. vector offset2 = offset0 - skewedOffset2 + G3a; // The offset from point 3 in regular space. vector offset3 = offset0 + G3b; // Wrap the integer indices at 256, to avoid indexing perm[] out of bounds. int i = int(skewedCellOrigin[0]) & 255; int j = int(skewedCellOrigin[1]) & 255; int k = int(skewedCellOrigin[2]) & 255; // Sine and cosine for the gradient rotation angle. float sinTheta = 0.0; float cosTheta = 0.0; sincos(M_2PI * flow, sinTheta, cosTheta); // Calculate the contribution from the four points. float t0 = 0.6 - dot(offset0, offset0); float t02 = 0.0; float t04 = 0.0; vector gradient0 = vector(0.0); float n0 = 0.0; if (t0 < 0.0) { t0 = 0.0; } else { t02 = t0 * t0; t04 = t02 * t02; gradient0 = getGradient(perm[i + perm[j + perm[k]]], sinTheta, cosTheta); n0 = t04 * dot(gradient0, offset0); } float t1 = 0.6 - dot(offset1, offset1); float t12 = 0.0; float t14 = 0.0; vector gradient1 = vector(0.0); float n1 = 0.0; if (t1 < 0.0) { t1 = 0.0; } else { t12 = t1 * t1; t14 = t12 * t12; gradient1 = getGradient(perm[i + int(skewedOffset1[0]) + perm[j + int(skewedOffset1[1]) + perm[k + int(skewedOffset1[2])]]], sinTheta, cosTheta); n1 = t14 * dot(gradient1, offset1); } float t2 = 0.6 - dot(offset2, offset2); float t22 = 0.0; float t24 = 0.0; vector gradient2 = vector(0.0); float n2 = 0.0; if(t2 < 0.0) { t2 = 0.0; } else { t22 = t2 * t2; t24 = t22 * t22; gradient2 = getGradient(perm[i + int(skewedOffset2[0]) + perm[j + int(skewedOffset2[1]) + perm[k + int(skewedOffset2[2])]]], sinTheta, cosTheta); n2 = t24 * dot(gradient2, offset2); } float t3 = 0.6 - dot(offset3, offset3); float t32 = 0.0; float t34 = 0.0; vector gradient3 = vector(0.0); float n3 = 0.0; if(t3 < 0.0) { t32 = 0.0; } else { t32 = t3 * t3; t34 = t32 * t32; gradient3 = getGradient(perm[i + 1 + perm[j + 1 + perm[k + 1]]], sinTheta, cosTheta); n3 = t34 * dot(gradient3, offset3); } // Accumulate the contributions from each point to get the final noise value. // The result is scaled to return values in the range [-1,1]. float noiseValue = 32.0 * (n0 + n1 + n2 + n3); // Compute noise derivative. // *dnoise_dx = -8.0f * t02 * t0 * x0 * dot(gx0, gy0, gz0, x0, y0, z0) + t04 * gx0; // *dnoise_dy = -8.0f * t02 * t0 * y0 * dot(gx0, gy0, gz0, x0, y0, z0) + t04 * gy0; // *dnoise_dz = -8.0f * t02 * t0 * z0 * dot(gx0, gy0, gz0, x0, y0, z0) + t04 * gz0; // *dnoise_dx += -8.0f * t12 * t1 * x1 * dot(gx1, gy1, gz1, x1, y1, z1) + t14 * gx1; // *dnoise_dy += -8.0f * t12 * t1 * y1 * dot(gx1, gy1, gz1, x1, y1, z1) + t14 * gy1; // *dnoise_dz += -8.0f * t12 * t1 * z1 * dot(gx1, gy1, gz1, x1, y1, z1) + t14 * gz1; // *dnoise_dx += -8.0f * t22 * t2 * x2 * dot(gx2, gy2, gz2, x2, y2, z2) + t24 * gx2; // *dnoise_dy += -8.0f * t22 * t2 * y2 * dot(gx2, gy2, gz2, x2, y2, z2) + t24 * gy2; // *dnoise_dz += -8.0f * t22 * t2 * z2 * dot(gx2, gy2, gz2, x2, y2, z2) + t24 * gz2; // *dnoise_dx += -8.0f * t32 * t3 * x3 * dot(gx3, gy3, gz3, x3, y3, z3) + t34 * gx3; // *dnoise_dy += -8.0f * t32 * t3 * y3 * dot(gx3, gy3, gz3, x3, y3, z3) + t34 * gy3; // *dnoise_dz += -8.0f * t32 * t3 * z3 * dot(gx3, gy3, gz3, x3, y3, z3) + t34 * gz3; dNoise dNoise = t02 * t0 * offset0 * dot(gradient0, offset0) + t04 * gradient0; dNoise += t12 * t1 * offset1 * dot(gradient1, offset1) + t14 * gradient1; dNoise += t22 * t2 * offset2 * dot(gradient2, offset2) + t24 * gradient2; dNoise += t32 * t3 * offset3 * dot(gradient3, offset3) + t34 * gradient3; dNoise *= -8.0; // Scale noise derivative to match the noise scaling. //dNoise *= (32.0 / 2.0); // Scale to the [0, 1] range. return 0.5 * noiseValue + 0.5; } /// 3D Fractal Simplex flow noise implementation. /// Returned values are in the [-1, 1] range. float fractalSimplexFlowNoise3D( point position, float flow, float lacunarity, float flowRate, float gain, float advect, int octaveCount ) { float noiseValue = 0.0; float flowValue = flow; float amplitude = 1.0; float advectionAmount = advect; for (int octave = 0; octave < octaveCount; ++octave) { vector flownoise3DGradient = vector(0.0); float noiseOctave = amplitude * (simplexFlowNoise3D(position, flowValue, flownoise3DGradient) - 0.5); noiseValue += noiseOctave; position -= advectionAmount * noiseOctave * flownoise3DGradient; position *= lacunarity; flowValue *= flowRate; amplitude *= gain; advectionAmount *= advect; } return noiseValue; } shader FractalSimplexFlowNoise [[ string description = "Fractal Simplex flow noise" ]] ( float start_frequency = 1.0 [[ string description = "Initial sampling position multiplier that affects the overall granularity." ]], vector start_offset = vector(0.0) [[ string description = "Offsets the initial sampling position effectively shifting the pattern in the specified direction." ]], float flow = 1.0 [[ string description = "The coordinate of a special noise dimension with a period of 1 that naturally evolves the noise to animate it instead of sliding a 3D slice throught the noise space." ]], float lacunarity = 2.0 [[ string description = "Position (frequency) multiplier per iteration." ]], float flow_rate = 1.0 [[ string description = "Flow coordinate multiplier per iteration." ]], float gain = 0.5 [[ string description = "Amplitude multiplier per iteration." ]], float advect = 0.5 [[ string description = "Both initial advection amount and advection multiplier per iteration." ]], int octaves = 8 [[ string description = "Number of fractal iterations." ]], float attenuation = 1.0 [[ string description = "The power of the falloff applied to the final result." ]], output color result = 0.0 ) { point objectPosition = transform("object", P); point startPosition = start_frequency * objectPosition - start_offset; float noiseValue = fractalSimplexFlowNoise3D(startPosition, flow, lacunarity, flow_rate, gain, advect, octaves); noiseValue = 0.5 * noiseValue + 0.5; noiseValue = pow(noiseValue, attenuation); result = color(noiseValue); }
