This page provides information about the Variations Variation tab in Chaos Envision.
width60%
The currently applied variation is highlighted in blue and indicated with a check mark () in the variations list. You can search, create and delete variations as described in the table below.
Search for a specific variation using the Search field. It filters the variations list and shows only those variations that contain the input string entry from the search field. Click thebutton on the right to clear the input stringsearch.
Create a new variation.
Delete the selected variation.
UI Text Box
typeinfo
A yellow frame around the viewport and a yellow highlight of the variation name appear every time a change is made to the current variation to prevent you from modifying it inadvertently.
width5%
width35%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeMenus
CardPageLinkEnvironment (Variations) Tab
Environment
Setup
Variations
Textboxcard
PageToIncludeMenus
CardPageLinkAnimation Tab
Variations in Animation
Textboxcard
PageToIncludeMenus
CardPageLinkEnvironment Tab
Environment Setup
Textboxcard
CardPageLinkCurrent View Quick Settings
Textboxcard
CardPageLinkFull Screen Viewport
