A menu is available when you right-click on an object in any filter tab. The menu contains the following options:
Duplicate – Duplicates the selected object. Shortcut: Ctrl+D
Delete – Deletes the selected object. Shortcut: Del
Rename – Renames the selected object.
Group nodes – Creates a group and adds the selected node(s) to the group.
Ungroup nodes – Ungroups the selected object(s).
Show/Hide – Toggles on and off the visibility of the selected object. Shortcut: Ctrl+Shift+H
Lock/Unlock – Locks or unlocks the transformation options in the Details tab of the selected object. Shortcut: Ctrl+Shift+L
Use environment from this scene – Copies the environment from the referenced scene to the environment of the main project. To do this, right-click specifically on the main component (top-level folder) of the imported scene.
