width60%
Search objects lights Searches for a specific light or lights. It filters the lights and shows only those match the search. Click the X button on the right to clear the search.
Expand/Collapse all – Expands or collapses lights that are in a hierarchy (parents and children).
Hide light indicators – Toggles on and off the visibility of all lights gizmos in the scene at once. Shortcut: G
Filter by sceneFilters the lights list by scene when multiple scenes are imported.
Lock  Disables the lights transformation options - position, rotation and scale. The options become greyed out. Click to enable the options for manipulation again.
Hide – Toggles visibility of individual lights on and off. Lights with disabled visibility are not rendered. The eye button is visible on hover of the light.
Invisible elements are indicated by the strikethrough eye, which is always visible and doesn't need a hover.
When a parent element is invisible in a hierarchy, the child light is indicated by a dot and also inherits the invisibility.
Group/ungroup nodes Right-click menu options that group and ungroup lights. The folder icon is an indicator for grouped lights. See the Menu Options section for more details.
Drag-and-drop – Places lights in hierarchy. Drag lights onto other lights to create a parent-child relationship.
width5%
width35%
