width50%
3D Gaussian Splatting is a method for creating a 3D scene from images or videos. It requires several pictures of an object, each taken from a different angle. With Gaussian Splatting, the images are blended to produce a detailed, three-dimensional representation of the object. Instead of depicting the scene as a collection of meshes, a Gaussian splat represents the scene as a type of point cloud, where each point is a 3D Gaussian.
Gaussian splats help you create a realistic environment for your scenes.
This feature is not yet available in V-Ray GPU.
UI Path: ||V-Ray menu|| > Geometry > V-Ray Gaussians
width40%
Image Added
width60%
width5%
width45%
