Note: The default system temp folder, usually C:\Users\<username>\AppData\Local\Temp on Windows (%TEMP%) or /tmp on Linux ($TMPDIR), is used for copying the assets if the VRAY_ASSETS_CACHE_PATH environment variable is not set.
cachedAssetsLimitType – Puts a limitation on the size and age of transferred assets.
configFile – The path and file name for the V-Ray config file, which contains paths to the V-Ray plugins. Note that additional paths for V-Ray plugins can also be specified with the VRAY_PLUGINS_x86 and VRAY_PLUGINS_x64 environment variables. The default is vrayconfig.xml in the same folder as vray.exe .
