UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for Nuke
urlhttps://download.chaosgroup.com/?platform=54&product=47
Progress Bar Container
step1
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
urlInstallation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
This section describes the installation of V-Ray for Nuke using the provided installer.
Tabs Container
directionhorizontal
Tabs Page
titleWindows
The V-Ray installer will automatically remove any previous installations. This will allow you to seamlessly upgrade from previous versions. If you experience problems you can manually uninstall the previous versions to perform a clean install. For more information please refer to the Uninstall V-Ray page.
Nuke VersionInstaller Name
Nuke 12.0 x64vray_adv_52000_Nuke12.0_x64.exe
Nuke 12.1 x64vray_adv_52000_Nuke12.1_x64.exe
Nuke 12.2 x64vray_adv_52000_Nuke12.2_x64.exe
Nuke 13.0 x64vray_adv_52000_Nuke13.0_x64.exe
Before running the installation, make sure your Windows account has administrative privileges.
To start the installation, double-click the installation file.
Once you've carefully read the License Agreement, click I Agree if you agree to the terms.
Select your installation type and proceed to click the Install button.
V-Ray type
The available installation types are:
Full – This is a full installation and includes all components as described in the “Installation overview” section.
Standalone only – This installation includes V-Ray Standalone. Please choose this option if you plan to use this machine only for Distributed Rendering with V-Ray Standalone.
If you need to customize your V-Ray installation, press the Advanced button.
UI Expand
titleClick here to expand for Advanced options...
Directories
Here you can specify the installation paths. Please check if the default folders are correct.
Help make V-Ray even better – Participate in the improvement decisions for future version of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. We do not gather scenes, assets, materials, etc. What we receive is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. This preference can be changed at any time later on from the About V-Ray > Feedback program settings. For more information, see the Chaos Telemetry page.
Licensing
In this step, you can specify whether the V-Ray license server will run locally or on another machine.
If you select the option Remote you will have to fill in the IP address of your V-Ray license server in the field Primary License Server. Please leave the port 30304 unchanged. An Alternate License Server is used when the primary one does not respond.
If you choose the Local Licensing Option, you are presented with the License Server installation.
Chaos License Server
At this step you can choose the license server directory.
Migrate data during installation – When enabled, transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option will install License Server with all settings at their defaults and any custom settings from the previous installation will be lost.
Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you will need to manually add firewall exceptions later.
If the installer detects any applications that need to be closed, they will be listed before being able to continue. Please close them and click Continue.
Now V-Ray is ready to render!  Don't forget to activate your license before use. No Chaos product can be used without a license!
Tabs Page
titleLinux
To install V-Ray for Nuke you have to be logged as root on your Linux account and execute the installer to run it:
Nuke versionInstaller name
Nuke 12.0vray_adv_52000_Nuke12.0_linux_x64
Nuke 12.1vray_adv_52000_Nuke12.1_linux_x64
Nuke 12.2vray_adv_52000_Nuke12.2_linux_x64
Nuke 13.0vray_adv_52000_Nuke13.0_linux_x64
V-Ray type
UI Expand
Directories
Licensing
Next Step
Go to step 2 to see how to activate your Chaos License
step1
url Installation
