This page provides an overview of the V-Ray Geometry nodes.
width50%
 Section Contents
Page Tree
root@self
width50%
Page Contents
stylecircle
V-Ray for Nuke provides several nodes for loading and modifying geometry and makes use of two specific file types: .vrmesh and .vrscene.
Fancy Bullets
typecircle
  • VRayClipper - A geometric primitive that can be used to clip away parts of the scene with a simple plane or defined mesh object.
  • VRayDisplacement - Allows geometry to be subdivided during render time as well as displacement mapping on objects.
  • VRayPlane - Creates a procedural infinite plane in the scene.
  • VRayProxy - Allows geometry from an external mesh to be imported at render time only. The geometry is not actually present in the scene and does not take any resources.
  • VRayVRScene - Loads a previously saved .vrscene file for rendering inside of V-Ray for Nuke.
  • VRayVRSceneGeometry - Loads a previously saved .vrscene file and extracts geometry nodes for rendering inside of V-Ray for Nuke.
