The V-Ray Swarm configuration interface allows you to create and track Tags for your render nodes, set up a Coordinator Node, change the server port and number of threads you use, setting up a custom license configuration, and using Environment environment variables.
Configuration Interface
Rendering with V-Ray Swarm requires V-Ray 3.0 Render Node license. In the License section, you have to configure the IP address/port of the machine where V-Ray license server is running.
By default, the Use system license configuration option is enabled, which uses the existing V-Ray license configuration from previously installed V-Ray products on the machine. For reference, please see Changing your License Settings.
Disabling Use system license configuration provides options for setting a custom configuration, which will be used only by V-Ray Standalone in Swarm. Note that this doesn't overwrite the system configuration if there is one, but creates a new one for V-Ray Swarm. Use this option if you want to change V-Ray license settings, or if you do not have any V-Ray products installed on the machine. You may choose three machines as Primary and Alternative license servers. Note that on these machines, you should have V-Ray license server running.
