UI Button | ||||||||||
Page Contents
Table of Contents | ||
A silent installation allows you to complete V-Ray installation without user input during the process using a predefined set of options. To set up a silent installation, you need to perform two steps: creating an .xml file and running the installer.
Code Block | ||||
<DefValues> <Value Name="REVERT_INSTALL" DataType="value">1</Value> <Value Name="REVERT_UNINSTALL" DataType="value">0</Value> <Value Name="SWARM_PORT" DataType="value">24267</Value> <Value Name="TTL_DEFAULT_VALUE" DataType="value">1</Value> <Value Name="AUTO_DISCOVERY" DataType="value">1</Value> <Value Name="STDROOT" DataType="value">C:\Program Files\Chaos Group\V-Ray\Swarm 1.4</Value> <Value Name="CONFIG_ROOT" DataType="value">C:\Program Files\Chaos Group\V-Ray\Swarm 1.4/config</Value> <Value Name="SHORTCUTS" DataType="value">1</Value> <Value Name="FIREWALL_EXCEPTION" DataType="value">1</Value> <Value Name="DISCOVERY_MASTERCOORDINATOR" DataType="value"></Value> <Value Name="DISCOVERY_ALTERNATE_MASTERCOORDINATOR_1" DataType="value"></Value> <Value Name="DISCOVERY_ALTERNATE_MASTERCOORDINATOR_2" DataType="value"></Value> <Value Name="INITIAL_CONFIGURATION_PATH" DataType="value"></Value> <LicServer> <Host>localhost</Host> <Port>30304</Port> <Host1></Host1> <Port1>30304</Port1> <Host2></Host2> <Port2>30304</Port2> <User></User> </LicServer> </DefValues> |
AUTO_DISCOVERY | When set to 1 V-Ray Swarm will try to discover other nodes automatically. When set to 0 the DISCOVERY_MASTERCOORDINATOR variable should be set to the IP of the machine where the master node Coordinator will run. Defaults to 1 |
DISCOVERY_MASTERCOORDINATOR | Specifies The IP address of the machine which will be used as a master node coordinator (required if AUTO_DISCOVERY is set to 0) |
DISCOVERY_ALTERNATE_MASTERCOORDINATOR_1 | Specifies the IP address of a machine, which will be used as a fallback master node coordinator if the primary master coordinator is not available (optional). |
DISCOERY_ALTERNATE_MASTERCOORDINATOR_2 | Specifies the IP address of the second fallback master nodecoordinator. (optional) |
INITIAL_CONFIGURATION_PATH | Specifies the absolute path to a swarm-config.json file to be used as the initial configuration for the new Swarm installation. This allows discovery settings, tags, environment variables, V-Ray settings and other config options to be configured at installation time. See the example file below. |
SWARM_PORT | Specifies the port on which the Swarm nodes communicate. Defaults to 24267 |
TTL_DEFAULT_VALUE | Specifies the Multicast TTL value used when AUTO_DISCOVERY is turned on. Defaults to 1 (same subnet) |
Swarm-Config.json Silent uninstallation
Fancy Bullets | ||
Code Block | ||||
{ "vray": { "port": 20208, "numberOfThreads": 0, "overrideLicense": false, "envVars": { "var1": "var1value", "var2": "var2value" }, "licenseServer": { "host": "127.0.0.1", "port": 30304, "port1": 30304, "port2": 30304 } }, "tags": [ "Default", "Tag1", "Tag2" ], "discover": { "autoDiscover": false, "masterNodescoordinators": ["10.10.10.10:24267"] } } |
vray.port | The network port on which the V-Ray standalone should listen for a request. Equivalent to the portNumber command-line option. Defaults to 20208 |
vray.numberOfThreads | The number of threads that V-Ray Standalone should use. When set to 0 V-Ray will use the number of threads equal to the number of logical processors. Defaults to 0 |
vray.overrideLicense | If set to false the system-wide vrlclient.xml file will be used for license information. If set to true the licenseServer entry will be used to generate vrlclient.xml file for V-Ray Standalone to use. Defaults to false |
vray.envVars
| The entries listed here are environment variables that will be set for V-Ray Standalone when it starts. |
licenseServer | The entries listed here are the same as the ones in vrlclient.xml. Note the everything is in lower case and the port numbers are not surrounded by quotes. |
tags | A list of tags for the Swarm instance. This list should not be empty. Each tag should be surrounded with quotes. |
discover.autoDiscover
| If set to true the Swarm instance will try to discover other instances in the network automatically. If set to false then a list of masterNodes coordinators should be provided. Defaults to true |
discover.masterNodescoordinators | A list of IPs of machines where Swarm master nodes coordinators run. This list should not be empty if discover.autoDiscover is set to false. |
You can use a command to perform a silent uninstall. In order to do that you need to know the full path of the folder containing V-Ray additional files and the exact name of the product, you want to uninstall. Then you can execute the following command:
Code Block |
"<STDROOT>\uninstall\installer.exe" -uninstall="<STDROOT>\uninstall\install.log" -uninstallApp="<PRODUCT_NAME>" -gui=0 -quiet=1 |
where <STDROOT> is the destination folder and <PRODUCT_NAME> is the product name i.e. “V-Ray Swarm”
For example, the following command will uninstall V-RaySwarm:
Code Blocknoformat |
"C:\Program Files\Chaos Group\V-Ray Swarm\uninstall\installer.exe" -uninstall="C:\Program Files\Chaos Group\V-Ray Swarm\uninstall\\install.log" -uninstallApp="V-Ray Swarm" -gui=0 -quiet=1 |
