AUTO_DISCOVERY | When set to 1 V-Ray Swarm will try to discover other nodes automatically. When set to 0 the DISCOVERY_COORDINATOR variable should be set to the IP of the machine where the Coordinator will run. Defaults to 1 |
DISCOVERY_COORDINATOR | Specifies The IP address of the machine which will be used as a coordinator (required if AUTO_DISCOVERY is set to 0) |
DISCOVERY_ALTERNATE_COORDINATOR_1 | Specifies the IP address of a machine, which will be used as a fallback coordinator if the primary coordinator is not available (optional). |
DISCOERY_ALTERNATE_COORDINATOR_2 | Specifies the IP address of the second fallback coordinator. (optional) |
INITIAL_CONFIGURATION_PATH | Specifies the absolute path to a swarm-config.json file to be used as the initial configuration for the new Swarm installation. This allows discovery settings, tags, environment variables, V-Ray settings and other config options to be configured at installation time. See the example file below. |
SWARM_PORT | Specifies the port on which the Swarm nodes communicate. Defaults to 24267 |
TTL_DEFAULT_VALUE | Specifies the Multicast TTL value used when AUTO_DISCOVERY is turned on. Defaults to 1 (same subnet) |
vray.port | The network port on which the V-Ray standalone should listen for a request. Equivalent to the portNumber command-line option. Defaults to 20208 |
vray.numberOfThreads | The number of threads that V-Ray Standalone should use. When set to 0 V-Ray will use the number of threads equal to the number of logical processors. Defaults to 0 |
vray.overrideLicense | If set to false the system-wide vrlclient.xml file will be used for license information. If set to true the licenseServer entry will be used to generate vrlclient.xml file for V-Ray Standalone to use. Defaults to false |
vray.envVars
| The entries listed here are environment variables that will be set for V-Ray Standalone when it starts. |
licenseServer | The entries listed here are the same as the ones in vrlclient.xml. Note the everything is in lower case and the port numbers are not surrounded by quotes. |
tags | A list of tags for the Swarm instance. This list should not be empty. Each tag should be surrounded with quotes. |
discover.autoDiscover
| If set to true the Swarm instance will try to discover other instances in the network automatically. If set to false then a list of coordinators should be provided. Defaults to true |
discover.coordinators | A list of IPs of machines where Swarm coordinators run. This list should not be empty if discover.autoDiscover is set to false. |
Code Block |
"<STDROOT>\uninstall\installer.exe" -uninstall="<STDROOT>\uninstall\install.log" -uninstallApp="<PRODUCT_NAME>" -gui=0 -quiet=1 |
where <STDROOT> is the destination folder and <PRODUCT_NAME> is the product name i.e. “V-Ray Swarm”
