This page provides details on the V-Ray for Unreal UI and how it is integrated into the Unreal interface.
Floatingpagetoc |
Responsivegridmacro | ||||||||||||||
The V-Ray for Unreal toolbar gives you access to all of the settings and options available in V-Ray.
V-Ray Toolbar
The V-Ray toolbar allows you to render using V-Ray’s Interactive renderer and bake lighting with V-Ray Bake. From the V-Ray drop-down menu you can access the V-Ray frame buffer, open the V-Ray Settings tab, open the V-Ray Project Settings and open the VRScene Export Options. From the V-Ray Bake drop-down you can access the V-Ray Bake Settings tab.
Section | |||||||||||||||||||||||||||||||||||
Button States
The V-Ray button and V-Ray Bake button have five states depending on the process that is currently running:
Section | |||||||||||||||||||||||||||||||||||||||||||||
V-Ray Render Button
V-Ray Bake Button
V-Ray Assets Category
Div | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
V-Ray Settings
V-Ray Bake Settings
Import vrscene Dialogue
The V-Ray Scene Import Options window appears when you are importing .vrscene files into Unreal.
Exporting vrscene Dialogue
The V-Ray Scene Export Options window appears when you export .vrscene files from Unreal.
