Chaos Cloud supports rendering still images and animations. If a Spherical Panorama VR camera is used in a still scene, Chaos Cloud automatically generates a responsive web page for reviewing the result on a VR headset such as Google Cardboard. Generating VR preview for the rest of the VR output cases is coming (e.g. Stereo, A VR camera is considered one of the following: Spherical Panorama, Stereo or Cube6x1/Cubemap camera, etc).
You can render scenes using Progressive or Bucket render mode, depending on the scene setup in the 3D application. Note that when using the Bucket render mode, the Bucket size is automatically set depending on the hardware type used for rendering. This ensures the best cloud rendering performance based on the machines' specifications and the performance tests we continuously run. If the Bucket size in the scene is different, it will be overridden.
Chaos Cloud is available for all 3D applications supported by V-Ray via vrscene file export (e.g. V-Ray for Cinema 4D). Chaos Cloud also integrates directly with V-Ray for SketchUp, Rhino, Revit, 3ds Max, Cinema 4D, Modo, Blender, Houdini and Maya. The Chaos Cloud client app is available for Windows 64-bit, macOS 10.9 or later, and Linux 64-bit.
