UI Text Box | ||
There are several important limitations of V-Ray GPU rendering in Chaos Cloud. See the the Supported Features page for more information. |
The output image types you will be able to download by rendering in Chaos Cloud are JPG and the file type you have specified in your scene’s settings. These settings are customized in the 3D application you use for designing your scene. If you don’t specify anything in the 3D application, Chaos Cloud will generate an EXR image besides the JPG.
If you have enabled the Include additional JPG output toggle in the Options page, Chaos Cloud generates an additional high-quality JPG file for your output for no extra charge.
Chaos Cloud is available for all 3D applications supported by V-Ray via vrscene file export. Chaos Cloud also integrates directly with V-Ray for SketchUp, Rhino, Revit, 3ds Max, Cinema 4D, Modo, Blender, Houdini and Maya. The Chaos Cloud The Chaos Cloud client app is available for Windows 64-bit, macOS 10.9 or later, and Linux 64-bit.
Responsivegridmacro | ||||||||||||||
Div | ||
