width55%
Clicking on a render job within a project opens the Job Details page. The page displays the finished render if it's finished, information about it, as well as additional controls for downloading, resubmitting, or reporting a job.
To download the render job, press the Download button. For more details on the download options, check the Save and Download Options page.
To delete the render job, press the Settings button () and select Delete.
To clone the render job, press the Clone button. For more information, see the Clone Option page.
To report the render job, if something went wrong, press the Settings button () and select Report.
To view the render log, press the Settings button ( ) and select View log details.
To rename the render job, press the Settings button ( ) and select Rename.
To move a job to another project, press the Settings button ( ) and select Move. Then, you can either search for a destination project (by entering the project title or browsing in the project list in a modal window), or you can create a new project and select it from the modal window.
UI Text Box
typetip
The project list in the modal window can be sorted by name.
UI Text Box
typetip
The progress of ongoing render jobs can be observed in real-time from the Job Details page.
UI Text Box
typeinfo
Cloning a render job using the Clone button allows you to set new final render settings.
UI Text Box
typenote
Please, note that when pausing a job, the credits consumption does not stop immediately. This means that when manually pausing a job, or when Chaos Cloud automatically pauses a job because the account's credits have been depleted or the job credit limit is reached, there might be some small additional credits consumption.
If a credit limit is used, the credits spent might be a bit above the limit (most of the time less than 0.1 credits). If the credits are depleted, the credits spent might be a negative number.
width5%
width40%
width55%
Chaos Cloud offers some bulk operations when selecting more than one job at once - Download, Save to Google Drive, Save to OneDrive and Delete.
You can select renders by clicking on them. Another way is to select the first and last render job while holding Shift.
When downloading the selected items, Chaos Cloud uses the Chaos Client app. Specify a location for the download to start. A separate tab opens in your browser where you can see the download process of each job.
For more information on saving to your drive, refer to the Save and Download Options page.
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/4kEHHP6mKqI" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
