This page provides an overview of the VRayPBRMtl and its parameters.
Floatingpagetoc |
Section | ||||||||||||||||
UI Paths
You can create a VRayPBRMtl through the ||Content Browser|| > Add New > V-Ray > VRayPBRMtl or from ||Content Browser|| > Add New > V-Ray > VRay Material Instance > Parent Material > VRayPBRMtl .
Section | |||||||||||||||||||||||||||||||||||||||
VRayPBRMtl Parameters
BaseColor
Metallic
Specular
Roughness
EmissiveColor
Opacity
UI Text Box | ||||
To use it you must also set the Blend Mode in the Material Property Overridesto Translucent or Alpha Composite. |
NormalTex
BumpTex
