To create a new empty project, press the button on the main menu on the left. A small pop-up window will appear asking you to enter a name for your project.
If Set as default is enabled, the newly created project will become the default one, meaning that all subsequent render job submissions will be automatically allocated to that project unless changed manually before submission.
To set a new default project, press the button while mouse-hovering over a project. To delete a project, press the button. To rename a project, press the button while hovering over a project's name.
Clicking on a project will open up its contained render items. Here you can monitor, pause, cancel or delete a render job.
be automatically redirected to the Queue section of V-Ray Cloud. This is where you can monitor and manage pending and on-going jobs.
