Panel | ||||||
Premium and Floating Licenses expand on the Solo and Fixed Licenses - they can also be shared between multiple users and devices, or they can be used locally - similar to the Solo and Fixed Licensesnot only used locally on the current machine. Sharing can be done in one of two ways:
The administrator can also assign floating licenses to individuals within the Organization. However, after that, the license is no longer available to be shared with others. For more information, see the User Management Actions page. When doing a sharedRemote setup for a Premium or Floating license, the license still needs to be installed locally on at least one machine in the network. This machine can use the license, but it also serves as a connection point for others to connect to the license. For the detailed workflowdetails on installing the license utility locally, see the Solo and Fixed Licenses page. If you have a dedicated administrator, you might want to only install the license server application on a dedicated license holder machine. If you are installing the License Server on a license-holder machine, see the Administrator Workflow page. To connect to a Premium or Floating License, as a remote user, you need to configure your Chaos product to connect to the License Server, which is deployed on the license-holder machine. This is done during the installation of your Chaos product. For more information, see the Premium and Floating Licenses page. Licenses can be shared and managed through themy.chaosportal. If you are the account holder (i.e. Administrator), you can assign individual licenses to members of your network, which they need to install locally on their machines. This method allows the administrator to manage the licenses centrally - individuals in the network cannot edit the license allocation.For more information, see theSelf-Service Portal Guide For Administrators. Keep in mind thata single license can be used by a single user at a time. You need to add more licenses if you wish multiple users to work simultaneously. Using a Premium or Floating license locally requires installing your Chaos product with the "Local License" setting in the installer and logging in with your Chaos account credentials when prompted.
UI Text Box | ||
Corona Activation If you are activating a Chaos License for Corona, please see the Activating Corona for 3ds Max or Activating Corona for Cinema 4D pages, depending on your integration. Enscape Activation Enscape 4.1 uses the Chaos Licensing system. You can follow the instructions here, or if you want an Ensape-specific guide, see the Enscape First Steps article. If you are using Enscape 4.0 or older, see the Enscape License Activation article. |
Re-configuring your License Installation
If you have upgraded your Chaos License plan, or if you misconfigured your license settings by mistake, here is how you can re-configure your Chaos product for a different Chaos License plan:
Fancy Bullets | ||
One option is to change your Chaos product's license setup. This method does not require re-installation. To change your Chaos product's license setup, see the Changing the Product License Setup page . Alternatively, you can re-install your current Chaos product by running its installation wizard again. At the Licensing step of the installation, you can change your license settings according your Chaos License plan. See the Workflows section for details. |
Div | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
