Section | |||||||||||||||||||||||||||
1) Open http://127.0.0.1:30304 and click on Online Licensing menu > Use licenses offline at the top right corner.
2) Click Next in the wizard to start.
3) Select products you want to use while this license server is disconnected from the Internet. Enter the number of machines you plan on using with these products and click PREVIEW.click Preview.
Anchor | ||||
4) Preview and adjust the precise number of licenses to borrow. Click the BORROW Borrow button to borrow the selected number of licenses.
UI Text Box | ||
You can use your borrowed licenses for 14 days without internet connection. Their renewal happens automatically. However, the renewal process requires internet connection at least once during the last 3 days. The renewal is valid from the moment it happened for additional 14 days. Therefore, if you borrowed it on June 1st and renewed it on June 11th, you can use the offline license until June 25th. |
Section | ||||||||
5) Finally, you can see your borrowed licenses and their expiration dates. Click the CLOSE Close button to return to the main menu.
Section | |||||
Releasing Licenses
Releasing licenses is useful in a few cases, for example if you borrowed licenses on one license server instance, but actually need them on another one. Or if you need fewer borrowed licenses than the ones you currently have. Or if your borrowed licenses get stuck on the backend of a certain FLP instance due to broken certificate.
UI Text Box | ||
If you deactivate your Online Licensing, the borrowed licenses will be released! |
Borrowing Licenses without Internet connection
Expand | ||
1) On the machine without Internet connection open the http://127.0.0.1:30304 page. 2) From the expandable menu of ONLINE LICENSING Online licensing, go to OFFLINE ACTIVATIONOffline activation. 3) Press ACTIVATE OFFLINE Activate offline button. 4) Download your activation request file (cert.crs).
5) Use another machine with Internet connection to log in to my.chaosgroup.com with your Chaos Group account. Go to Licensing > License Servers and press Activate License Server. 6) Name your license server and press NEXT Next.
7) Upload the activation request file you downloaded in step 4 and press ACTIVATE Activate.
8) Download your Activation file (cert.crt).
9) On the machine without Internet connection in your http://127.0.0.1:30304 page upload your Activation file (cert.crt) and press UPLOAD Upload.
10) Your site is now successfully activated.
1) Log into my.chaosgroup.com with your Chaos Group account from the machine with Internet connection. On the License Servers tab of the page, choose a workstation from the list for which you wish to reserve licenses for offline use.
2) Click Borrow Licenses in license in the Borrowed Licenses licenses section.
3) Select products you want to use. Enter the number of machines you plan on using with these products and click PREVIEW LICENSESPreview.
Anchor | ||||
4) Preview Preview and adjust the precise number of licenses to borrow. Click Click the BORROW Borrow button to borrow the selected number of licenses. Anchor
5) Click Download Offline Licenses Fileoffline licenses file.
6) On the machine that is running the license server, open http://127.0.0.1:30304 and click on Online Licensing menu > Use licenses offline at the top right corner.
7) Upload the offline license *.bin file and press the Upload button.
8) Once the file is validated, your borrowed licenses will also be listed on your license server's home page.
Editing Borrowed Licenses
1) To add new licenses, log into my.chaosgroup.com with your Chaos Group account from machine with Internet connection.
2) From the Licensing tab, go to License Servers, click on your license server, and press Edit Borrowed Licenses.
3) If you want to increase the number of borrowed licenses you already have, you can use the plus buttons. If you want to borrow licenses for new products, you can use the Add more licenses drop-down menu. When you are ready, press Borrow.
4) Repeat steps 4-8 from the Borrowing Licenses without Internet connection section.
