Section | |||||||||||||||
Configuration File
HTTP Proxy - The proxy is an HTTP proxy. Note that this does not mean that the proxy cannot pass over HTTPS requests. Choosing this setting will prompt prompts you for a proxy address and port. Contact your network administrator for details on this setting.
Log Level – Adjusts the verbosity level of the information printed to the diagnostics log. The higher the verbosity level, the more information is logged, where the Errors Only settings will log logs the least amount of information, and Verbose will create creates a full log. The more information is logged, the larger the log files become.
Port - Controls the port where the License Server Interface is accessible. Do not change this value unless necessary.
Fancy Bullets | ||
UI Text Box | ||
When using a dongle license connected to the License Server you are only able to access the dongle licenses on the machine that the dongle is connected to. You are unable to access dongle licenses over the internet on another machine logged into the License Server. |
