Updating the Contents of the Dongle
The support team at Chaos will Chaos will use your “.wbc” file to generate one or more “.rtu” files and send them back to you. Each “.rtu” file is named with the serial number of the dongle that it is intended for. You can find the dongle serial number on its sticker.
UI Text Box | ||
Do not plug more than one dongle at a time while updating the contents of the dongle! |
Windows
When you receive the “.rtu” file, save it on the machine where the dongle with the same serial number is plugged-in.
You need to make sure your dongle is disabled. To disable it from within the License Server, select Disable dongle from the Dongle menu.
Double-click the saved “.rtu” file. You will be asked to confirm the transfer on the dongle. Click Yes to update your dongle.
Re-enable the dongle from the License Server by selecting ENABLE DONGLE.
