Code Block |
vrlctl online enable -h |
UI Text Box | ||
Note that at the moment you cannot borrow and release licenses with the help of the vrlctl command. |
Commands
The following commands are available:
The version option prints the version of the Licensing Server Controller.
Code Block |
vrlctl -v |
Anchor
Enabling Online Licensing without Internet connection
- In the command line, type vrlctl online getcsr to save an online licensing request file (cert.csr) in the current directory.
- Visit https://my.chaosgroup.com/license-server and follow the instructions to instructions to activate the license server by getting an online license key file (cert.crt).
- Type vrlctl online enable to enable online licensing using the newly obtained key file from the current directory.
