- From the Desktop, right-click the Computer icon and select Properties. If you don't have a Computer icon on your desktop, click the Start button, right-click the Computer option in the Start Menu, and select Properties.
- Click the Advanced System Settings link in the left column.
- In the System Properties window, click on the Advanced tab, then click the Environment Variables button near the bottom of that tab.
- In the Environment Variables window (pictured below), click on New.. in the "System variables" section.
- Add the Variable name - VRAY_AUTH_CLIENT_FILE_PATH
- Add the Variable value - //SERVER/path/to/directory/
macOS
By default the vrlclient.xml location is /Users/YourUsername/.ChaosGroup folder.
- Place the edited file in /Library/LaunchAgents/ directory.
UI Button | ||||||
