An instance of the Chaos License Server that uses the same user account may be installed more than once on the same internal network when on different workstations or servers to act as a redundancy measure. You can also use V-Ray environment variable VRAY_AUTH_CLIENT_FILE_PATH.
- Place the edited file in /Library/LaunchAgents/ directory.
UI Button | ||||||
